Hi -
After I upgraded a MacBook Pro with Intel CPU to MacOS 14.x, my iCloud-based vaults are failing to mount (example log below).
I’m using MacFuse 4.5.0. I see the error “Documents/com~apple~CloudDocs/Personal - iCloud/masterkey.cryptomator: Operation not permitted”; is this a MacFuse issue?
These vault opens fine with Cryotomator on iOS and a different laptop running MacOS 14.1 with Apple silicone.
Error Code 91OE:23FV:3V7A
org.cryptomator.cryptolib.api.MasterkeyLoadingFailedException: I/O error
at org.cryptomator.cryptolib@2.1.2/org.cryptomator.cryptolib.common.MasterkeyFileAccess.load(MasterkeyFileAccess.java:121)
at org.cryptomator.desktop@1.11.1/org.cryptomator.ui.keyloading.masterkeyfile.MasterkeyFileLoadingStrategy.loadKey(MasterkeyFileLoadingStrategy.java:74)
at org.cryptomator.cryptofs@2.6.8/org.cryptomator.cryptofs.CryptoFileSystems.create(CryptoFileSystems.java:53)
at org.cryptomator.cryptofs@2.6.8/org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:196)
at org.cryptomator.cryptofs@2.6.8/org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:86)
at org.cryptomator.cryptofs@2.6.8/org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:126)
at org.cryptomator.desktop@1.11.1/org.cryptomator.common.vaults.Vault.createCryptoFileSystem(Vault.java:126)
at org.cryptomator.desktop@1.11.1/org.cryptomator.common.vaults.Vault.unlock(Vault.java:145)
at org.cryptomator.desktop@1.11.1/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
at org.cryptomator.desktop@1.11.1/org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:70)
at org.cryptomator.desktop@1.11.1/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:60)
at org.cryptomator.desktop@1.11.1/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:31)
at javafx.graphics@20.0.2/javafx.concurrent.Task$TaskCallable.call(Unknown Source)
Caused by: java.nio.file.FileSystemException: /Users/charles/Library/Mobile Documents/com~apple~CloudDocs/Personal - iCloud/masterkey.cryptomator: Operation not permitted
at java.base/sun.nio.fs.UnixFileSystemProvider.newByteChannel(Unknown Source)
at java.base/java.nio.file.Files.newByteChannel(Unknown Source)
at java.base/java.nio.file.spi.FileSystemProvider.newInputStream(Unknown Source)
at java.base/java.nio.file.Files.newInputStream(Unknown Source)
at org.cryptomator.cryptolib@2.1.2/org.cryptomator.cryptolib.common.MasterkeyFileAccess.load(MasterkeyFileAccess.java:118)
... 20 more
