I’m encountering problems locking my vault. I’ve closed all terminals and finder windows that I thought might be holding some resource. I cannot quit Cryptomator gracefully… I click “Quit” and “Lock and Quit” buttons and it fails to quit or even give any error feedback.
First stack where it would not quit nor lock my vault:
08:34:38.085 [JavaFX Application Thread] ERROR o.cryptomator.ui.common.VaultService - Failed to lock Bountiful Voluntaryists
org.cryptomator.common.vaults.Volume$VolumeException: org.cryptomator.frontend.fuse.mount.CommandFailedException: Command failed with exit code 1. Expected 0. Stderr: umount: gn41PQ2t0q0__0: not currently mounted
at org.cryptomator.common.vaults.FuseVolume.unmount(FuseVolume.java:147)
at org.cryptomator.common.vaults.Vault.lock(Vault.java:136)
at org.cryptomator.ui.common.VaultService$LockVaultTask.call(VaultService.java:172)
at org.cryptomator.ui.common.VaultService$LockVaultTask.call(VaultService.java:156)
Caused by: org.cryptomator.frontend.fuse.mount.CommandFailedException: Command failed with exit code 1. Expected 0. Stderr: umount: gn41PQ2t0q0__0: not currently mounted
at org.cryptomator.frontend.fuse.mount.ProcessUtil.assertExitValue(ProcessUtil.java:26)
at org.cryptomator.frontend.fuse.mount.AbstractMount.unmount(AbstractMount.java:51)
at org.cryptomator.common.vaults.FuseVolume.unmount(FuseVolume.java:144)
... 8 common frames omitted
Second stack where my other vault wouldn’t lock:
08:46:35.710 [JavaFX Application Thread] ERROR o.cryptomator.ui.common.VaultService - Failed to lock cryptomator
org.cryptomator.common.vaults.Volume$VolumeException: org.cryptomator.frontend.fuse.mount.CommandFailedException: Command failed with exit code 1. Expected 0. Stderr: umount(/Volumes/vOApXTdyQFrg_0): Resource busy -- try 'diskutil unmount'
Caused by: org.cryptomator.frontend.fuse.mount.CommandFailedException: Command failed with exit code 1. Expected 0. Stderr: umount(/Volumes/vOApXTdyQFrg_0): Resource busy -- try 'diskutil unmount'
System Details:
Cryptomator v 1.5.5
Volume Type FUSE
macOS Catalina 10.15.7
