I installed the newest version 1.6.17
My OS is a sort of Kubuntu 22.04.
My local folder for my sync with Nextcloud is placed on a secondary drive. Obviously, I want to use this folder to create a vault for Cryptomator. Unfortunately, I have no possibility to select this location in the setup dialogue.
Under Dolphin, the hard drive is displayed normally in the Devices tab and the setup dialogue in the Nextcloud client also “finds” the hard drive.
The properties in Dolphin show that the secondary disk has the address /, with the mount point /datadisk.
Mounted from /dev/nvme0n1p1
Do I need to change anything on my system, or how can I get Cryptomator to create a vault on the secondary disk?
