Hi guys,
So I have last problem and only problem in my replaced windows with linux.
Status:
- Gsuite Google Drive cca 20 TB
- some folders cca 2-5GB are locked with Cryptomator
- I have 4-5 vaults
Use:
- I use files in Vaults and need to access them fast from many dif devices.
Usually few files per day. - Files outside vaults are not important, I can use browser based google drive access, low priority.
- I use sucessfully Android Cryptomatic and Win client and it works perfect “on the fly” with, as dropbox call it, smart sync. On Google side we have windows and
Google Drive File Stream (requires GSuite Bussiness) and allows me to see all my files when online without using hard drive space on my machine and if I want to keep any files offline, I just right-click and mark it for offline.
Problem:
- I cant find solution for Linux (Mint 19) for Google File Stream or any other which can allow me that Vault is not entierly downloaded before use.
Before we agree that this is not Cryptomator topic, I would like to ask how it can be done via Android app where Cryptomatic access vaults perfectly and files are not stored localy?
Maybe there can be any solution?
Worst case for me is to have virtualbox and Win only for smartsync Vaults -.-
