Hi
I am currently working on integrating a new cloud provider (not sure if I will succeed in the end, therefore not saying which one).
I already own Cryptomator through Google Play Store but for developing locally it would be much easier to have a license key since it’s needed. I’m not even sure if I can build it locally and get my license through Google Play.
Would it be possible that you provide me with a license key?
Thanks in advance.
Regards,
Manuel
That sounds very ingenious. I assume you have already stumbled across the wiki entry about How to add a new cloud provider. If not, this should be a good starting point. If problems arise or I can support in any way let me know.
Regarding the license I’ll send you a direct message.
Right, there is a wiki on GitHub, thanks for pointing that out.
I was looking at the Dropbox and OneDrive impkementation and was trying to adapt.
I’ll let you know what I’m planning to do via DM, thanks.
