Download the zip:
DELETED
extract it, and copy ui-1.5.11.jar
inside Cryptomator\app
folder, and voilà, easy dark mode without paying for something is very bad coded.
virus scans if you’re scared:
DELETED
Happy new year and enjoy!
Download the zip:
DELETED
DELETED
This is an official statement of Skymatic, the maintainer behind Cryptomator:
First of all, Cryptomator is free software, which means that we grant you the right to make any changes (including removal of disliked code) in accordance to GPLv3. This also means we will not start a cat-and-mouse game and obfuscate any license-related code, as we believe in clean design.
That said, we make use of our domestic authority in this forum and removed the link for the following reasons:
Each of these points alone is sufficiently backing our decision.
Ok, anyway, people should be able to find the file on other forums. this is not the only one where I published it. In the other hand, I can assure you, protected or no, I can make it work, and finally I’ll try to keep it up to date or maybe I’ll make it auto-“updateable”.
Have a good day!
