For the latest version of cryptmator in win10, when the language is set to Chinese, the system tray displays garbled code [edit Michael: when using WinFSP). Change the configuration file to GBK and the display is normal. However, using ‘fuse’ at this time, the attached ‘F:’ disk cannot be accessed. How can we solve the two problems at the same time? Is this a bug?
Currently, this is not possible. To use WinFSP, the encoding has to be utf-8. See Windows: Cryptomator tray menu has broken Unicode text · Issue #1474 · cryptomator/cryptomator · GitHub
Thank you for your answer. For me, it’s just that the tray is a little messy and can tolerate it, as long as it doesn’t affect the use of ‘fuse’, because WebDAV can only operate up to 4G files at a time
