With latest version (1.5.6).
Completely stuck with this issue.
Version used: latest version (1.5.6).
Steps to reproduce:
-Login to pCloud (as usual).
-P drive was created/mapped in Windows 10 Home (latest version 2004)
-Back to Cryptomator and enter password.
See these errors after CORRECT password was entered.
java.io.IOException: Error during file system creation.
at org.cryptomator.cryptofs.CryptoFileSystems.create(CryptoFileSystems.java:53)
at org.cryptomator.common.vaults.Vault.unlockCryptoFileSystem(Vault.java:120)
at org.cryptomator.common.vaults.Vault.lambda$getCryptoFileSystem$0(Vault.java:98)
at java.base/java.util.concurrent.atomic.AtomicReference.updateAndGet(Unknown Source)
at org.cryptomator.common.vaults.Vault.getCryptoFileSystem(Vault.java:98)
at org.cryptomator.common.vaults.Vault.unlock(Vault.java:127)
Caused by: java.io.UncheckedIOException: java.nio.file.FileSystemException: P:\masterkey.cryptomator.966227ED.bkup: The request could not be performed because of an I/O device error
at org.cryptomator.cryptofs.CryptoFileSystemModule.provideCryptor(CryptoFileSystemModule.java:47)
at org.cryptomator.cryptofs.CryptoFileSystemModule_ProvideCryptorFactory.provideCryptor(CryptoFileSystemModule_ProvideCryptorFactory.java:56)
at org.cryptomator.cryptofs.CryptoFileSystemModule_ProvideCryptorFactory.get(CryptoFileSystemModule_ProvideCryptorFactory.java:43)
at org.cryptomator.cryptofs.DaggerCryptoFileSystemProviderComponent$CryptoFileSystemComponentImpl.cryptoFileSystem(DaggerCryptoFileSystemProviderComponent.java:329)
... 22 more
Caused by: java.nio.file.FileSystemException: P:\masterkey.cryptomator.966227ED.bkup: The request could not be performed because of an I/O device error
at java.base/sun.nio.fs.WindowsFileSystemProvider.newByteChannel(Unknown Source)
at java.base/java.nio.file.Files.newByteChannel(Unknown Source)
at org.cryptomator.cryptofs.common.MasterkeyBackupHelper.backupMasterKey(MasterkeyBackupHelper.java:58)
at org.cryptomator.cryptofs.CryptoFileSystemModule.provideCryptor(CryptoFileSystemModule.java:43)
... 33 more
