Hi, i run Cryptomator on Linux OpenSuse 15.1 in AppImage mode (Java 11, latest).
When i unlock the folder, i receive this error:
java.nio.file.AccessDeniedException: /************/c
at java.base/sun.nio.fs.UnixFileSystemProvider.createDirectory(Unknown Source)
at java.base/java.nio.file.Files.createDirectory(Unknown Source)
at java.base/java.nio.file.Files.createAndCheckIsDirectory(Unknown Source)
at java.base/java.nio.file.Files.createDirectories(Unknown Source)
at org.cryptomator.cryptofs.common.FileSystemCapabilityChecker.determineSupportedFileNameLength(FileSystemCapabilityChecker.java:118)
at org.cryptomator.cryptofs.common.FileSystemCapabilityChecker.determineSupportedFileNameLength(FileSystemCapabilityChecker.java:95)
at org.cryptomator.common.vaults.Vault.unlockCryptoFileSystem(Vault.java:108)
at org.cryptomator.common.vaults.Vault.lambda$getCryptoFileSystem$0(Vault.java:98)
at java.base/java.util.concurrent.atomic.AtomicReference.updateAndGet(Unknown Source)
at org.cryptomator.common.vaults.Vault.getCryptoFileSystem(Vault.java:98)
at org.cryptomator.common.vaults.Vault.unlock(Vault.java:127)
at org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:102)
at org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:79)
at org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:42)
but on Windows all work good. Any ideas?
Thanks in advance
