Just started using Cryptomator on my MacBook and iOS, I created a Vault on my MacBook and In iCloud and am not able to see it via the iOS app and vice versa. This is really frustrating as there are times I would save files to my vault on Mac but would also need to save to same vault on my iOS device. Should this work? Can I access the same vault from my iOS and MacOS Cryptomator apps? If so how?
Thanks!
TJ
Hi people I suffer kinda same problem since installing Cryptomator 1.4.0 and Fuse for Mac.
Until that I used the same Cryptomator safe on iPhone and Mac as intended, simultaneously.
After the mentioned upgrade to 1.4.0 and Fuse, I can see the same looking safe on each device, but what I store on the iPhone is not displayed in the Mac app and vice versa.
I read the hint regarding the root folder, but until and after the upgrade, I changed no settings.
