I feel like I haven’t seen this mentioned anywhere. Basically I want to be able to open the Cryptomator program on my PC, access the file through the File Stream network drive, open it, add/change files, then lock it and have it upload into my drive.
Even Cryptomator only suggestions the regular Google Drive folder as opposed to the File Stream network drive. Will there be issues saving to File Stream instead of regular Backup and Sync?
Edit: I tested it a few minutes ago and it seems that it won’t work. For whatever reason, File Stream doesn’t seem to be able to handle the uploading/downloading quickly enough. My guess is that in the duration between changing the vault’s contents, locking it, then immediately having the virtual drive disappear, File Stream isn’t able to reconcile all of the files correctly. What ended up happening is my “d” folder had a few folders that flat out would never sync and the overall folder size was off.
