Dear all
My system Win 10 LTSC 2019.
I can’t Extraction Winrar and running some program in Vault
You can see picture
Executables: Read/Try this please: Why WebDAV and Dokan have issues running many executables?
Winrar: any error messages? Log file warnings?
Dear sr.
I can run Winrar. But i can’t run some portable.
Can’t run portable software in a vault
infeo
May 25, 2021, 8:43am
4
If you are using Dokany and the application requires an elevated privilege, this is a known issue, see
opened 01:27PM - 22 Jan 20 UTC
closed 03:14PM - 02 Mar 23 UTC
type:bug
os:windows
mount:dokany
### Description
- I cannot directly run any executable from a mounted vault
… - other scenario: I cannot run installers or portable apps directly from a RAR archive, where the path for extraction of temporary files is set to a secure vault
### System Setup
* Operating system and version: Windows 10 Enterprise
* Cryptomator version: 1.5.0 Beta 2, same issue was under 1.4.13 / 1.4.15, not sure when it started on previous builds
* Drive: [Dokany]
### Steps to Reproduce
1. an executable is on any path in the mounted vault
2. when double click to run it, an error pops up saying windows cannot find the network path
#### Expected Behavior
I can start an executable from the mounted vault
I can set the vault to be the temporary path for RAR archives so that I can directly start executables from within the archive
#### Actual Behavior
I get either of the 2 below errors in the attached images
Most frequently:
<img width="307" alt="Capture2" src="https://user-images.githubusercontent.com/2428217/72897915-4f314480-3d23-11ea-95d3-adbd6fdf2fae.PNG">
Rarely:
<img width="389" alt="Capture" src="https://user-images.githubusercontent.com/2428217/72897914-4e98ae00-3d23-11ea-90dc-df752ff4fea0.PNG">
#### Reproducibility
Always
### Additional Information
But there is a workaround, see:
Most of your questions were already answered. But i can sum it up for you:
If you experience problems with Dokany or WebDAV, you can try WinFSP. The drawback of WinFSP is, that you cannot mount into a folder. Additionally, you need to reset the custom mount options for every vault by deselecting them.
To use it, you need to download and install WinFSP manually. Afterwards, restart Cryptomator, open the general preferences and select “FUSE” in the virtual volume tab.
The usage of WinFSP is st…
Dear
I have user: Admin and user The . You can see picture
when I use user Admin, I can run portable program.
But when I use user The . And I run as Administrator. But I still get the error as picture
Ok.
When i change from WebDAV to Dokany. I can run portable program in the Vault
Thank you.
