I just changed my mobile device, on the old device if I could open audio files inside cryptomator, it opened a small window above the cryptomator interface. On the new device I can’t open any audio files I install some players, but none of them let me play the audio.
Should I install a player that opens on top of the cryptomator window with a small window like my old device, is there a player you recommend or what can I do, I am an Android 12 user, the device is a Moto G Play 2023. I have been using Cryptomator for several years and have never had a single problem, this is the first one.
I thank you in advance for any help you can give me. Thank you very much.
I just tested this out on my Samsung Galaxy S21.
When I click on an audio file it downloads it from the cloud where it is stored and then I get a pop-up window asking me which app I would like to open the file with and I selected Samsung music player and it played the music.
You might need to look at settings for your phone and see if there is a way to define what program will run audio files or if you can possibly be prompted when you click on a file what app you would like to use.
I can’t see any settings in the app that would affect your ability to play music.
Yes, on my old device, it played with a popup window the audio files from Cryptomator, but on this Motorola I don’t have that option and I have to look for a player hopefully FOSS, that can open files from cryptomator.
All the files opened without problems, only the audio files did not want to open. I did not find in F-Droid any player that opened a popup window when opening an audio file. However in the PlayStore I found, Oto Music, I installed like 12 players and they were not useful, they had full advertising and many permissions, but this Oto Music App, opens a popup window and plays the audio without problem, and also updates automatically if I delete a file from the gallery or any App that has audio as a recorder. The other deleted the audio file and was not removed from the player was updated every 5 min I think, well with this App works well, and it seems that it is not very inbasiva. also has no advertising. I hope I’m not wrong, so far Cryptomator works 100% as usual. Thank you.
