Hi, I am using Cryptomator 1.15.2 on windows 11 and had already some adventures setting up my vault, which I explain here: Recover files without master key and vault - #2 by pagin
I cannot access many of my files with the following error:
Meanwhile, the underlying files of my vault, as per the file system’s edit date, have never changed since I embarked, so I think that the data should be fine. All directory and file names are correct, so I seem to have the correct key for my files, even if I needed to reconstitute it after it got lost somehow.
New files which I created meanwhile are perfectly accessible.
Does anyone have an idea about how I can access my old files?
Thanks
Philippe
