Hey there
I’m trying to setup hub for family use, but stuck with this error:
ERROR [io.qua.ver.htt.run.QuarkusErrorHandler] (executor-thread-1) HTTP Request to /api/config failed, error id: baa872aa-97c4-49c3-9dbe-1d73aa2832ce-114: java.lang.NullPointerException: Cannot invoke "io.quarkus.oidc.runtime.OidcProvider.getMetadata()" because "io.quarkus.oidc.runtime.TenantConfigBean.getDefaultTenant().provider" is null
at io.quarkus.oidc.runtime.OidcConfigurationMetadataProducer.produce(OidcConfigurationMetadataProducer.java:26)
at io.quarkus.oidc.runtime.OidcConfigurationMetadataProducer_ProducerMethod_produce_a59da20ebfc42c6899b40e9ef42b822382f9d2af_Bean.doCreate(Unknown Source)
at io.quarkus.oidc.runtime.OidcConfigurationMetadataProducer_ProducerMethod_produce_a59da20ebfc42c6899b40e9ef42b822382f9d2af_Bean.create(Unknown Source)
at io.quarkus.arc.impl.RequestContext.getIfActive(RequestContext.java:74)
at io.quarkus.arc.impl.ClientProxies.getDelegate(ClientProxies.java:30)
at io.quarkus.oidc.OidcConfigurationMetadataProducer_ProducerMethod_produce_a59da20ebfc42c6899b40e9ef42b822382f9d2af_ClientProxy.arc$delegate(Unknown Source)
at io.quarkus.oidc.OidcConfigurationMetadataProducer_ProducerMethod_produce_a59da20ebfc42c6899b40e9ef42b822382f9d2af_ClientProxy.getAuthorizationUri(Unknown Source)
at org.cryptomator.hub.api.ConfigResource.getConfig(ConfigResource.java:49)
at org.cryptomator.hub.api.ConfigResource_Subclass.getConfig$$superforward(Unknown Source)
at org.cryptomator.hub.api.ConfigResource_Subclass$$function$$1.apply(Unknown Source)
at io.quarkus.arc.impl.AroundInvokeInvocationContext.proceed(AroundInvokeInvocationContext.java:73)
at io.quarkus.arc.impl.AroundInvokeInvocationContext$NextAroundInvokeInvocationContext.proceed(AroundInvokeInvocationContext.java:97)
at io.quarkus.security.runtime.interceptor.SecurityHandler.handle(SecurityHandler.java:27)
at io.quarkus.security.runtime.interceptor.PermitAllInterceptor.intercept(PermitAllInterceptor.java:23)
at io.quarkus.security.runtime.interceptor.PermitAllInterceptor_Bean.intercept(Unknown Source)
at io.quarkus.arc.impl.InterceptorInvocation.invoke(InterceptorInvocation.java:42)
at io.quarkus.arc.impl.AroundInvokeInvocationContext.proceed(AroundInvokeInvocationContext.java:70)
at io.quarkus.arc.impl.AroundInvokeInvocationContext.proceed(AroundInvokeInvocationContext.java:62)
at io.quarkus.resteasy.reactive.server.runtime.StandardSecurityCheckInterceptor.intercept(StandardSecurityCheckInterceptor.java:44)
at io.quarkus.resteasy.reactive.server.runtime.StandardSecurityCheckInterceptor_PermitAllInterceptor_Bean.intercept(Unknown Source)
at io.quarkus.arc.impl.AroundInvokeInvocationContext.perform(AroundInvokeInvocationContext.java:30)
at io.quarkus.arc.impl.InvocationContexts.performAroundInvoke(InvocationContexts.java:27)
at org.cryptomator.hub.api.ConfigResource_Subclass.getConfig(Unknown Source)
at org.cryptomator.hub.api.ConfigResource$quarkusrestinvoker$getConfig_26efc0c58e5a85c8a7d0d04e72f6a132d5d501aa.invoke(Unknown Source)
at org.jboss.resteasy.reactive.server.handlers.InvocationHandler.handle(InvocationHandler.java:29)
at io.quarkus.resteasy.reactive.server.runtime.QuarkusResteasyReactiveRequestContext.invokeHandler(QuarkusResteasyReactiveRequestContext.java:141)
at org.jboss.resteasy.reactive.common.core.AbstractResteasyReactiveContext.run(AbstractResteasyReactiveContext.java:145)
at io.quarkus.vertx.core.runtime.VertxCoreRecorder$14.runWith(VertxCoreRecorder.java:576)
at org.jboss.threads.EnhancedQueueExecutor$Task.run(EnhancedQueueExecutor.java:2513)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1538)
at org.jboss.threads.DelegatingRunnable.run(DelegatingRunnable.java:29)
at org.jboss.threads.ThreadLocalResettingRunnable.run(ThreadLocalResettingRunnable.java:29)
at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30)
The related part of docker-compose.yaml
init-config:
container_name: init-config
image: bash:5
volumes:
- $SERVER_DIR/cryptomator/db-init:/db-init
command:
- bash
- '-c'
cat >/db-init/initdb.sql << 'EOF'
CREATE USER hub WITH ENCRYPTED PASSWORD 'hub';
CREATE DATABASE hub WITH ENCODING 'UTF8';
GRANT ALL PRIVILEGES ON DATABASE hub TO hub;
EOF
postgres:
container_name: postgres
image: postgres:14-alpine
depends_on:
init-config:
condition: service_completed_successfully
volumes:
- $SERVER_DIR/cryptomator/db-init:/docker-entrypoint-initdb.d
- $SERVER_DIR/cryptomator/db-data:/var/lib/postgresql/data
deploy:
resources:
limits:
cpus: '1.0'
memory: 256M
healthcheck:
test:
- CMD
- pg_isready
- '-U'
- postgres
interval: 10s
timeout: 3s
restart: unless-stopped
environment:
POSTGRES_PASSWORD: postgres
POSTGRES_INITDB_ARGS: '--encoding=UTF8'
networks:
- cryptonet
hub:
container_name: hub
image: ghcr.io/cryptomator/hub:stable
depends_on:
postgres:
condition: service_healthy
deploy:
resources:
limits:
cpus: '1.0'
memory: 512M
healthcheck:
test:
- CMD-SHELL
- (curl -f http://localhost:8080/q/health/live && curl -f http://localhost:8080/api/config) || exit 1
interval: 10s
timeout: 3s
environment:
HUB_PUBLIC_ROOT_PATH: /
HUB_KEYCLOAK_PUBLIC_URL: https://crypt.local.{{ domain }}/kc
HUB_KEYCLOAK_LOCAL_URL: https://crypt.local.{{ domain }}/kc
HUB_KEYCLOAK_REALM: cryptomator
HUB_KEYCLOAK_SYNCER_USERNAME: syncer
HUB_KEYCLOAK_SYNCER_PASSWORD: e9f94369-817c-46c6-b653-43d6c8d720c0
HUB_KEYCLOAK_SYNCER_CLIENT_ID: admin-cli
HUB_KEYCLOAK_SYNCER_PERIOD: 5m
HUB_KEYCLOAK_OIDC_CRYPTOMATOR_CLIENT_ID: cryptomator
QUARKUS_OIDC_AUTH_SERVER_URL: https://crypt.local.{{ domain }}/kc/realms/cryptomator
QUARKUS_OIDC_TOKEN_ISSUER: https://crypt.local.{{ domain }}/kc/realms/cryptomator
QUARKUS_OIDC_CLIENT_ID: cryptomatorhub
QUARKUS_DATASOURCE_JDBC_URL: jdbc:postgresql://postgres:5432/hub
QUARKUS_DATASOURCE_USERNAME: hub
QUARKUS_DATASOURCE_PASSWORD: hub
QUARKUS_HTTP_HEADER__CONTENT_SECURITY_POLICY__VALUE: default-src 'self'; connect-src 'self' api.cryptomator.org https://crypt.local.{{ domain }}/kc/; object-src 'none'; child-src 'self'; img-src * data:; frame-ancestors 'none'
networks:
- cryptonet
- traefiknet
labels:
- "traefik.enable=true"
- "traefik.docker.network=traefiknet"
- "traefik.http.routers.hub-https.rule=Host(`crypt.local.{{ domain }}`)"
- "traefik.http.routers.hub-https.entrypoints=websecure"
- "traefik.http.routers.hub-https.service=hub"
- "traefik.http.services.hub.loadbalancer.server.port=8080"
- "traefik.http.routers.hub-https.tls=true"
- "traefik.http.routers.hub-https.tls.certresolver=myresolver"
Any help would be appreciated.
