How to sync entire Cryptomator/OneDrive folders on iPhone?
Hello, I recently switched from Boxcryptor to Cryptomator… and I used Cryptomator now to encrypt my files one OneDrive - on Windows Desktop it seems to work fine… all files and folders are uploaded and encrypted. Then I installed the Cryptomator app on iPhone (but not the OneDrive app) and I now can see the cloud stored folders in my files app successfully. I also already downloaded one single file on my iPhone manually… so in general it seems to work at that end fine as well. Now I would like to download/sync a whole folder or rather several folders (but not all) which are stored in OneDrive… is there a way to do so?
Hi. On iOS the files in your vault are managed like any other file.
To download a complete folder, open the files app, and navigate to the folder to see the files in it.
Click the three dots in the right upper corner and click „select“. Then select all files. Then click the three dots in the right lower corner and select „load now“. Then all files are downloaded.
