I am using cryptomator for a long time -> Perfect utility to encrypt data.
the masterkey.cryptomator is a single point of disaster for all my business files.
question:
How to take care of the masterkey.cryptomator and masterkey.cryptomator.bkup file ?
cheers
Cryptomator is not a backup solution. So if you are afraid of loosing the masterkey file, or any other file in or of your vault, You’ll have to backup these files.
Haha … that’s a good one …
Yes you are correct.
Cryptomator encryptes your files,
Use other tool to backup these encrypted files ( inclusive the masterkey and backup of the masterkey.
