As a part of my learning experience, I created a number of test vaults. To my surprise, when I right click one of them in Cryptomator (1.5.17) and select “remove”, it gets removed from the CM vault list, but the actual vault remains on the hard drive. So is this the correct procedure?
- Close the unwanted vault.
- Right-click on it in the CM list of vault and select “Remove”
- Shift-Delete the folder with the vault from the hard drive.
Correct?
