On desktop PC with Windows10 I use Yandex disk. I installed yesterday Cryptomator, but how to connect it with Yandex ?
Cryptomator Desktop does not connect to anything.
It creates encrypted files on your local file system (the vault), which are access via a virtual drive that appears as soon as the vault is opened.
So if you are creating a vault and want to have it synced with your yandex disc, please select a local storage path that is included into the yandex sync.
The sync is done by the yandex client.
