quick question from a new (almost) user: I really want to try Cryptomator but I can’t figure out how to choose a custom folder for the new vault that is not in /home/user/… I can’t access my other hard drives with sync folders. In settings I have chosen “FUSE” for volume type which claims “custom directory as mount point”. What am I doing wrong? Any help would be appreciated. Thank you!
Well, that was fast. And also correct. Tried setting the access rights of the Flatpak installation using Flatseal and creating a vault on a different hard drive. That worked like a charm. Thanky ou very much for the support. Looking forward to using Cryptomator!
