Don’t want to bother anyone but my post is only for “look and feel”. Cryptomator is working magic. Virtual drive appears successfully in my explorer with current letter “Z” I did choose. Icon attached to the disk seems to be a blank page. I rather like to have Cryptomator icon located into “program files\cryptomator” however after fews tries and tricks I did not manage to change it. Any idea. Many thanks.
we already have a feature-request in one of our subprojects for this.
There you can also find some links how to change the icon. Additionally, check out the following external article:
https://www.tenforums.com/tutorials/74659-change-drive-icon-windows-10-a.html
Hello Infeo,
Many many thanks. Before posting, I read a proposal a bit similar but because I did not see my disc under DriveIcons key, I thought it was not possible.
In fact in your link it is clearly described that if driver letter key is not there then it is ok to create it.
Magic, I follow all step by step and finally it works fine. So from process view nothing more but from look and feel, I feel good …
