How does Cryptomator work with Dropbox's selective local sync?
Good morning. I’m about to install Cryptomator and migrate my entire Dropbox contents to a Cryptomator vault. I make extensive use of Dropbox’s selective local sync feature, so I can keep infrequently used files in the cloud and the most frequently used files sync’d locally. How does Cryptomator work with this feature? Does it allow certain files in a vault to be sync’d locally and others kept in the cloud, or will I be required to keep a local copy of every file? That’ll use up my 2TB SSD rather quickly.
see here: Does Cryptomator work with dropbox smart-sync and "online-only" files?
