Right click on my decrypted Cryptomator drive and select Properties, I see a “Used Space” amount that seems WAY bigger than what I think the actual content would add up to. Any thoughts?
What virtual volume provider are you using? You find the setting in the general preferences, virtual volume tab.
If it is WebDAV, you are affected by Virtual drive shows capacity of system partition (C:) - #2 by overheadhunter
Virtual drive says Dokany
Is there an update on this?
