I can’t get Cryptomator to work anymore. I have tried everything I found in google and suggested by people on here from a previous thread. I need to use something else.
How exactly do I unencrypt my files so that I can encrypt them another way?
Just copy/move thefiles out of your vault to somewhere else on your PC. Then the files are not encrypted anymore.
Oh…derp. That was easy.
What if all the files are stored on Google Drive should I still move them out of the vault or can I just uninstall Cryptomator?
Uninstalling the app will not change anything of your vault. You are just not able to access your files in the vault if you uninstall the app.
Thanks, I appreciate it.
