We have started a new documentation project for Cryptomator and wanted to make contributions to the documentation as easy as possible and think we found a good solution.
Do you…
- … have a GitHub account (can be set up in 2 minutes)?
- … know Markdown (that is the name of the syntax you use for your posts in this forum
- … know how Cryptomator 1.4.x works?
- … speak English?
Then you might want to help us with the documentation on https://docs.cryptomator.org.
Just click on the Edit on GitHub button on the documentation pages and send us a pull request. We will then review your changes and merge them.
We might even add further languages in the future.
