I do not know what has happened and how to resolve. I would appreciate it if you could help.
java.nio.file.FileSystemAlreadyExistsException
at org.cryptomator.cryptofs.CryptoFileSystems.lambda$create$0(CryptoFileSystems.java:49)
at org.cryptomator.common.vaults.Vault.unlockCryptoFileSystem(Vault.java:126)
at org.cryptomator.common.vaults.Vault.lambda$getCryptoFileSystem$0(Vault.java:104)
at java.base/java.util.concurrent.atomic.AtomicReference.updateAndGet(Unknown Source)
at org.cryptomator.common.vaults.Vault.getCryptoFileSystem(Vault.java:104)
at org.cryptomator.common.vaults.Vault.unlock(Vault.java:130)
UPDATE: After the computer restart, the application appears to be working normally again.
