I just ran a complete Health Check of my vault and the Directory Check found a vast number of problems. These can be fixed one by one but due to the quantity it would take me forever to click off every single problem one by one. Is there a way to fix all the problems at once?
So for those who have the same problem and want to save a lot of clicking this is how I solved it. I just used Macro Recorder which you can easily set up to do the clicking for you. There were few thousands problems to fix for me and it took the program just few minutes. You can even get along with the demo version which is limited to 10 playbacks. Just copy the commands many times as I did (see screenshot). I know it is not the most elegant solution, but it works.
Is there a way for Fixing all warning? Not just the infos? I’ve done it with the MacroRecorder (thanks!) but i need a button for fixing all (infos, warnings etc.)
Found this:
If an error is fixable it should exist a button to fix all fixable errors not just the infos. I have hundreds of warnings and all are fixable but only one for one. Please add an option to fix all fixable errors!
For documentation: The fix-all-button implemented in #2553 is not a “fix-everything” button, but only fixes all INFO results. Otherwise the task would have been too complex.
