Using Cryptomator 1,5,16 (exe- 2831.223). Updated from Google Backup & Sync to Google Drive for desktop. Cryptomator fails to open existing vault: seems to be an intermittent drive letter confusion problem i.e. sometimes fails but sometimes works OK on repeated attempts.
On failure, Cryptomator reports as follows:-
… 11 more
… 13 more
Thanks for any help with fixing this little snag.
