I’ve newly installed Cryptomator on my MacOS Catalina system. When I try to locate a vault, I am not being offered Google Drive (which I use). I have already installed OSX Fuse and it’s up to date. I’m trying to determine why this is the case.
I have CloudMounter which will mount the drive itself. I also have a couple other similar applications I could use for the same if I need.
Cryptomator desktop does not connect directly to a cloud storage. It always saves the encrypted files on your Lokal storage, which you then have to sync to your online storage via the storage app. In your case google backup and Sync.
