Gnome-Keyring safe option doesn't work
i’m using cryptomator for some time now and so far it worked fine. Some time ago i have upgraded to Debian 13 Trixie and started with a new fresh install, recovered my home folder and now i have the problem that Cryptomator does no longer safe the password into my gnome-keyring. The option is set, an entry is created (shown in seahorse) but the password section in the created entry stays blank. If i’m trying to manually add the password to that entry it is safed(asks if i’m sure) but again empty after reopening seahorse. Cryptomator asks everytime for the password(“Remember Password” is set). I have changed the default keyring to “Login” does not work(have found this tip here in the community from 2022). Deleted the default keyring and created a new one called Login, same situation. Same behavior with AppImage and flatpak latest version.
Flatpak:
installed with –user option
Thanks
