GMX Tresor not supported anymore
Hi experts,
I used the gmx tresor long time, but now it is not supported anymore and after new PC installation I cannot open my tresor anymore.
I tried with cryptomator after getting info, that this tool has been used. But under gmx tresor there is not such a masterkey file “masterkey.cryptomator” as used with cryptomator.
I tried rename the similiar looking file: “systemdaten.gmxtresor” into “masterkey.cryptomator” and then to open the tresor (vault), but it did not succeed. I could enter the password, but it is not opening.
Any idea?
Thanks
Duik
unfortunately, Cryptomator cannot open the GMX Tresor.
While it is true, that the GMX Tresor is based upon Cryptomator and Cryptomator developers co-developed it, there is currently no way to open a GMX Tresor with Cryptomator. You have to contact GMX support if you have not already done so. The decryption does not work with Cryptomator, even if you rename files, and GMX is primarily responsible (already by contract) for the GMX Tresor. Unfortunately, our hands are tied.
You may find this discussion useful which shows how to open a GMX Tresor in Cyberduck.
