I am syncing my Cryptomator store with Resilio Sync. Now and then I am experiencing a weird bug that seems to happen because of the combination of Cryptomator and Resilio Sync.
The bug occurs when I rename an exisiting directory with content in it. E.g. when I rename a directory from “sport” to “acitivites”. Sometimes the original folder “sport” reappears after ResilioSync synced the changes to the other hosts. The result is that I have both folders “sport” and “activities” in my Cryptomator store, both containing the same documents.
So the first time I thought - ok, just delete the old directory, seems to be a resync triggered from Resilio but when I do, the new folder also gets deleted. So when I delete “sport”, the folder “activities” also gets removed. This is pretty bad because the first time I noticed the missing directory a week later.
Last little thing … When I want to recreate the new folder “activites”, Windows Explorer throws an error like “the source file or volume can not be read” (“die Quelldatei oder vom Quelldatenträger kann nicht gelesen werden” in German).
Anyone a clou how I can avoid this from happening? It’s breaking my current setup because of this bug I cannot relate on my Cryptomator store to be saved correctly.
Regards Daniel
