Hi. The same history, fuse-t displays not all folders in storage. Part of folders are shown and disappear. How to correct it? When I pass on web dav displays all folders, but Web dav sometimes breaks finder and FUSE-t not correctly works.
MacOS Ventura 13/2/1
opened 07:13PM - 19 Mar 23 UTC
type:bug
os:mac
mount:fuse
- [X] I have searched [existing issues](https… ://github.com/cryptomator/cryptomator/issues?q=) for duplicates
- [X] I agree to follow this project's [Code of Conduct](https://github.com/cryptomator/cryptomator/blob/develop/.github/CODE_OF_CONDUCT.md)
### Summary
Only about half the files/folders in my Vault are visible after upgrade
### What software is involved?
- Operating System: macos 13.2.1
- Cryptomator: 1.7.3
- Fuse-T: 1.0.17
### Volume Type
FUSE-T
### Steps to Reproduce
1. Unlock Vault
2. List files in Vault, e.g. in cli via command "ls"
### Expected Behavior
Get a list of all files in Vault
### Actual Behavior
Only about half the files/folders are visible.
Additionally this log is printed:
ls: fts_read: Input/output error
### Reproducibility
Always
### Relevant Log Output
```shell
### Anything else?
This Issue occured after I upgraded Cryptomator from 1.6.x directly to 1.7.3
I have also switched from the kext fuse version to Fuse-T at the same time.
However, switching back to osxfuse didn't help.
Workaround due to that post: Downgrade FUSE-T to version 1.0.16
