If you are reading this, but have not yet lost your vault password, I would like to take this opportunity to remind you to
- create a recovery key and save it in a safe place
- create continuously backups of the unlocked vault
If you lost your vault password, you have still some options to recover from:
Recovery Key
In the best case, during vault setup, you created a recovery key which you can use to reset your password.
Backup
Still a good option, you created backups of the vault content which means you can create a new vault and copy the content into the new vault.
Cracker
Your password isn’t too long, you have a powerful PC and nothing to lose, you can use the vault password cracker which will consume a lot of time and energy (for good reason).
