Win10 Pro 21H2
Cryptomator 1.6.11
Fuse mount
I have set up a Vault to mount as a folder (C:\Vault) which works well. However when I set up the Vault to mount automatically upon Cryptomator startup, the folder mount settings are forgotten and instead it mounts as the next available drive (in my case, D:). The folder mount settings are forgetten so I need to set up the folder mount settings again and mount it manually.
Is this expected behaviour that folder mounts can not be automatically mounted upon Cryptomator startup?
