Just installed flatpak 1.9.3 flatpak-1.
Have created a vault successfully but could not open it.
Error Code 6HCL:2GTN:8714
org.cryptomator.integrations.mount.MountFailedException: org.cryptomator.jfuse.api.FuseMountFailedException: fuse_mount failed
at [org.cryptomator.frontend.fuse@3.0.0/org.cryptomator.frontend.fuse.mount.LinuxFuseMountProvider$LinuxFuseMountBuilder.mount(LinuxFuseMountProvider.java:116)](mailto:org.cryptomator.frontend.fuse@3.0.0/org.cryptomator.frontend.fuse.mount.LinuxFuseMountProvider$LinuxFuseMountBuilder.mount(LinuxFuseMountProvider.java:116))
at [org.cryptomator.desktop@1.9.3/org.cryptomator.common.mount.Mounter.mount(Mounter.java:134)](mailto:org.cryptomator.desktop@1.9.3/org.cryptomator.common.mount.Mounter.mount(Mounter.java:134))
at [org.cryptomator.desktop@1.9.3/org.cryptomator.common.vaults.Vault.unlock(Vault.java:150)](mailto:org.cryptomator.desktop@1.9.3/org.cryptomator.common.vaults.Vault.unlock(Vault.java:150))
at [org.cryptomator.desktop@1.9.3/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)](mailto:org.cryptomator.desktop@1.9.3/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79))
at [org.cryptomator.desktop@1.9.3/org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:70)](mailto:org.cryptomator.desktop@1.9.3/org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:70))
at [org.cryptomator.desktop@1.9.3/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:60)](mailto:org.cryptomator.desktop@1.9.3/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:60))
at [org.cryptomator.desktop@1.9.3/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:31)](mailto:org.cryptomator.desktop@1.9.3/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:31))
at [javafx.graphics@20.0.1/javafx.concurrent.Task$TaskCallable.call(Unknown](mailto:javafx.graphics@20.0.1/javafx.concurrent.Task$TaskCallable.call(Unknown) Source)
at java.base/java.lang.Thread.run(Unknown Source) Caused by: org.cryptomator.jfuse.api.FuseMountFailedException: fuse_mount failed
at [org.cryptomator.jfuse.linux.amd64@0.5.1/org.cryptomator.jfuse.linux.amd64.FuseImpl.mount(FuseImpl.java:35)](mailto:org.cryptomator.jfuse.linux.amd64@0.5.1/org.cryptomator.jfuse.linux.amd64.FuseImpl.mount(FuseImpl.java:35))
at [org.cryptomator.jfuse.api@0.5.1/org.cryptomator.jfuse.api.Fuse.mount(Fuse.java:127)](mailto:org.cryptomator.jfuse.api@0.5.1/org.cryptomator.jfuse.api.Fuse.mount(Fuse.java:127))
at [org.cryptomator.frontend.fuse@3.0.0/org.cryptomator.frontend.fuse.mount.LinuxFuseMountProvider$LinuxFuseMountBuilder.mount(LinuxFuseMountProvider.java:113)](mailto:org.cryptomator.frontend.fuse@3.0.0/org.cryptomator.frontend.fuse.mount.LinuxFuseMountProvider$LinuxFuseMountBuilder.mount(LinuxFuseMountProvider.java:113))
... 13 more
