First Beta of Cryptomator 1.6.0
For those of you who want to switch from 1.6.0 alpha 1 to 1.6.0 beta 1, you will notice that there is not update check working and thus no automatic update process. You have to do that by hand.
I just installed the 1.6.0 beta 1 ā€œoverā€ the alpha 1, confirmed that the folder i want to install already exists and then let the installer do its job.
Didn’t want to mount all my vaults again and assumed this will be the less risk way to loose this configuration instead of uninstalling the alpha and risk to delete the configuration as well. And I was right. All vaults there. So far no problems.
New version shown in ā€œaboutā€ tab is ā€œSNAPSHOT (msi-3205)ā€.
(Seems that the Name ā€œBeta 1ā€ didn’t make it in the ā€œaboutā€ tab of this beta :slight_smile: )
Many thanks Michael, 1.6.0 B1 working perfect on my Linux Manjaro xfce desktop. :smiley:
