Files are disappeared in folders and subfolders
Hi, I checked older posts but they do not help. Since two weeks, all of my files in folders and subfolders are disappeared. Files in the main folder are still there. This is in Mac:os and iOS. My vault lies on oneDrive. If I click a folder, I can see that oneDrive synchronizes something. I copied the vault to iCloud and it is still the same. But the files must be there. The vault is about 0,5gb big.
Have someone the same problem? Can someone help? I tried an older version of fuse-t, but it didn´t help.
Best regards,
Thomas
Is your vault still the correct size? What version of the app are you using?
Try locking your vault, wait until all OneDrive files are fully synchronized by the app, and then try again. Do you see any errors in the logs?
Have you tried copying the vault to a second location and running a health check? I believe the app can occasionally restore directories from backup files. Just remember to work on a copy.
I guess, that the vault has the correct size. I use version 1.15.1. In the logs I get several warnings.
App Background Thread 003
[webdav-029] WARN
JavaFX Application Thread
[webdav-023] WARN
[webdav-028] WARN
[webdav-028] ERROR
How can I run a health check? Sorry for the question, but I didn’t find this in the community.
