Hello all,
When i try to move a file (10gb in size) in a vault i created, it says the file is only 2gb after the move in the vault.
I got no error whatsoever.
Could you explain ?
Thanks in advance.
Hello all,
Could you explain ?
Thanks in advance.
Ok, problem solved. I wasn’t using Dokany driver.
