File compression
It would be very nice, if Cryptomator could also compress files before encrypting them, for example using gzip. This would be an easy-to-use reduction of the vault’s size.
There could be a checkbox to enable compression, if you create a new vault.
Hey, thank you for the suggestion! We already have a feature request for this on our issue tracker:
