Hi Guys,
automount feature (decrypt vault at startup) works very well!
FR: If I want to shut down my PC without “locking the vault” it works. On the next power-on, Cryptomator cannot automount the vault in the specified path (because shutdown while vault was open?).
Same situation shall be occure by an unexpected shutdown (bluescreen, POR).
I guess for both (unexpected shutdown, user force a shutdown while vault is open) is for cryptomator an “unexpected shutdown”. A routine which will check at startup “unexpected shutdown?” may be helpful?
Version: 1.4.15
OS: Windows 10 x64
Thank you,
Cheers!
