Hi there, the new feature that tells us which vault is open, with fewer clicks is great (I had even written in requesting, back in October). Thank you.
If there are unlocked vaults, can you consider upgrading this feature to be “glanceable”? I.e. to indicate if there is any unlocked vault even on the top level icon somehow?
I suggest this as locking all vaults I would guess is a high frequency interaction by users: for security, as otherwise there is an uncrypted copy of vault contents that is disk resident; and so there are no misadventures when using sync’d copies of the same vault across different machines.
Thank you for the consideration
thisonefella
