I have been using Cryptomator regularly and setting a few shortcuts for folders and files inside the vault. The problem is sometimes the program mounts my drive in different drive letters and that breaks the shortcuts.
So, I was wondering if it could have an option to manually set a drive letter for each vault.
This should already be possible. Go to the “Vault Options” of each vault, select the “Mounting” tab, and select “Use assigned drive letter” at the bottom at “Mount Point”.
I couldn’t find it first but seems like we can only change the options when the vault is locked.
Maybe they can be visible and give us a warning like “restart the vault” if we try to change them while mounted.
Thanks a lot.
