ccchan
March 20, 2018, 2:18am
#1
hi~
i put file on google drive.
if i use file based encryption as by competitor,
i just upload once and can move literally to all places
provided that inside the encrypred folder.
for ctmt, for what i guess,
if i got 2 vault on google,
Move between them will mean:
dnld, decrypt, encrypt, upload.
even both vault is same password…
any chance to deal with this? thx
sorry for my many post on comments.
i do wish ctmt to be better.
clarify:
competitor:
/encrypted-folder1
/unencrypted-folder
/encrypted-folder2
when move from 1st to 3rd, no need any upload/dnld/encrypt/decrypt.
ctmt:
/vault1
/unencrypted-folder
/vault2
i think even vault1 and 2 have same password, ctmt need dnld/decrypt/encrypt/upload…
thz
correct. because only your password is not the encryption key.
Even if 2 vaults have the same password, the encryption is different.
From my point of view: no.
What I do not understand: why do you set up 2 vaults in 1 storage (e.G. google Drive) with the same password? what is the intention? where is the added value for you?
ccchan
March 25, 2018, 12:10am
#4
Sometimes I dont have enough time to organize and just upload everthing first on google drive,
and create a new vault and name it with date.
This repeated in the other day.
Then later I wanna organize them into a 3rd vault.
That’s OK, may be I can change my way by
make a super large vault for my whole google drive,
then each time make just a new folder with date, instead of a new vault.
Thanks
