Fatal Error in Java Runtime Environment JRE
Hello!
I run Crypotomator 1.15.1 (deb-1)
I have activated autostart and receive the following error messages in the log files (hs_err_pidxxxx.log):
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007377d2c4798b, pid=4810, tid=4847
# JRE version: OpenJDK Runtime Environment (23.0.1+11) (build 23.0.1+11-coffeelibs)
# Java VM: OpenJDK 64-Bit Server VM (23.0.1+11-coffeelibs, mixed mode, tiered, compressed oops, compressed class ptrs, g1 gc, linux-amd64)
# Problematic frame:
# C [libc.so.6+0x4798b]
# Core dump will be written. Default location: Core dumps may be processed with “/usr/lib/systemd/systemd-coredump %P %u %g %s %t 9223372036854775808 %h” (or dumping to /home/chris/core.4810)
further down in the log file is the cause:
JVM Arguments:
java_class_path (initial) /usr/lib/cryptomator/lib/app/httpcore-4.4.16.jar:/usr/lib/cryptomator/lib/app/jackrabbit-webdav-2.22.0.jar
Launcher Type SUN_STANDARD
java_command org.cryptomator.desktop/org.cryptomator.launcher.Cryptomator
It seems that this error does not occur during manual startup.
Welcome to the Cryptomator community :slightly_smiling_face:
there is similar report on our issue tracker, see
Albeit, up to now noone had time to look into it.
