I upgraded to Cryptomator-1.6.10-x64, and it fails with the error below when I unlock existing vaults. I did install the same version on a “new pc” with no problems. Any ideas on what to do? /Peter
Error Code TMN6:3HIN:SRPV
at org.cryptomator.desktop@1.6.10/org.cryptomator.common.vaults.DokanyVolume.mount(DokanyVolume.java:48)
at org.cryptomator.desktop@1.6.10/org.cryptomator.common.vaults.Vault.unlock(Vault.java:153)
at org.cryptomator.desktop@1.6.10/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
at org.cryptomator.desktop@1.6.10/org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:72)
at org.cryptomator.desktop@1.6.10/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:62)
at org.cryptomator.desktop@1.6.10/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:35)
at javafx.graphics@18.0.1/javafx.concurrent.Task$TaskCallable.call(Task.java:1426)
at org.cryptomator.frontend.dokany@1.3.3/org.cryptomator.frontend.dokany.MountFactory.mount(MountFactory.java:130)
at org.cryptomator.frontend.dokany@1.3.3/org.cryptomator.frontend.dokany.MountFactory.mount(MountFactory.java:116)
at org.cryptomator.desktop@1.6.10/org.cryptomator.common.vaults.DokanyVolume.mount(DokanyVolume.java:43)
... 11 more
Caused by: com.dokany.java.DokanyException: Dokany not properly installed (Reported versions: 151/0
at org.cryptomator.frontend.dokany@1.3.3/com.dokany.java.DokanyMount.checkReportedVersions(DokanyMount.java:140)
at org.cryptomator.frontend.dokany@1.3.3/com.dokany.java.DokanyMount.mount(DokanyMount.java:88)
at org.cryptomator.frontend.dokany@1.3.3/org.cryptomator.frontend.dokany.MountFactory.mount(MountFactory.java:126)
... 13 more
