Hello!
I’m excited about using Cryptomator, but I’m encountering some surprises.
I’ve been using NextCloud for a number of years, and that’s worked out really well.
I’d like to migrate my data to a Cryptomator Vault, and am also evaluating hosting that Vault in Google Drive.
A rather brief tests revealed some unexpected behavior -
- File and directory permissions are not maintained when I move files, or when I tar and untar files. I tested this with a vault that is on Google drive, as well as a vault hosted in NextCloud and a local vault (not synced with any cloud) - and got the same results. Explicitly setting permissions on a file (chmod 0644) in a Cryptomator vault has no effect - the permissions remain 0700.
- Moving files into a Cryptomator Vault hosted in Google Drive is extremely slow. My Google Drive preferences are set to mirror files.
Is there some setting I’m missing or something I can do to address these issues? The first one particularly makes Cryptomator a non-starter for me.
I’m running Cryptomator 1.6.5 on macOS 11.6.2 (Big Sur).
Thanks so much!
