Errors with android app and pCloud
Hey there,
I installed app from the cryptomator repository via F-Droid where pCloud is included. I have a lineageOS phone with microG. I was able to connect the app with pcloud and connect my vault afterwards. Then I can access the root folder of the fault fine. It will also instantly sync this folder level. So there are no sync issues because I created a test file and it instantly appeared on my linux machine. But for most subfolders the app says “something went wrong” and doesn’t display anything. When I close the app and try to re-login later on. The login prompt will also instantly display an error message below the password field. If I enter my password correctly, the app won’t login anymore. I will just get one-time access again if I delete the vault and add it again.
So far I couldn’t really find a case which fits to my problem.
Please let me know, if you need more information. Thanks in advance for your support.
BR Peter
More info would definitely be helpful but I’m not sure exactly what because I use pcloud everyday and never have a problem.
One thing I do not do is synchronize with pcloud my Vault down to my computer I only access my vault in the cloud.
Hi Leo,
thank you for your answer. I just had a look in the log files and found that the app throws this error message:
ErrorCode: 3O07:PL32
W 20260302213116.694 Message Ein Fehler ist aufgetreten
W 20260302213117.661 CryptoFs Failed to parse cipher text name of: /myVault/d/B2/SOME30CHARS/dirid.c9r
W 20260302213118.876 CryptoFs Failed to parse cipher text name of: /myVault/d/RK/SOME30CHARS/dirid.c9r
E 20260302213123.498 ExceptionHandler java.lang.NumberFormatException: Expected a long but was 18446744073709551615 at line 5 column 34 path $.metadata.created
at com.google.gson.stream.JsonReader.nextLong(JsonReader.java:1111)
I hope this helps to narrow it down.
BR Peter
It would be good for you to do a DEBUG capture to a log file.
Open Settings on the main menu by clicking the gear icon in lower left.
Then, enable DEBUG.
Here are pictures:
Hi Leo,
I don’t really understand why you want me to get the log file of the desktop version of cryptomator.
I have the log file. Is there anything you are searching for in particular? I don’t really want to share it here.
There is just one error in it:
19:20:19.303 [JavaFX Application Thread] ERROR o.purejava.appindicator.AppIndicator - Directory ‘/etc/ld.so.conf.d/’ does not exist
19:20:19.309 [JavaFX Application Thread] INFO  o.purejava.appindicator.AppIndicator - Native code library libayatana-appindicator3.so.1 failed to load
19:20:19.310 [JavaFX Application Thread] INFO  o.purejava.appindicator.AppIndicator - Native code library libappindicator3 successfully loaded
When I do a health check on the vault it returns without any errors.
BR Peter
My bad.
I should have asked you to upload a debug of the Android app running debug mode. Perhaps you will see the error there.
You can activate it in settings.
