Hey, thanks for your quick response!
Yes, that \sciebo directory is a standard directory within the NTFS filesystem. “sciebo” is basically an owncloud-type client that watches the directory and syncs files with the cloud, just as, e.g., dropbox.
I enabled the Cryptomator diagnosis Protocol, created a new text file, saved it, then deleted it. This simple action lead to ~7k lines in the logfile. The content appears to be quite repetetive, and the “release failed” seems to appear as a result of deleting the file. I hope that the attached log file excerpt contains relevant parts:
(edit: pasted stuff without setting font to italic because that seems counter-productive here)
> creationTime: 2022-02-05T22:18:13.7328071Z, isRegularFile: false, isDirectory: true, isSymbolicLink: false, isOther: false, size: 20480, fileKey: null)
> 00:23:43.357 [Thread-303077] TRACE o.c.f.fuse.locks.DataRLockImpl - Released read data lock for '[]'
> 00:23:43.357 [Thread-303077] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[]'
> 00:23:43.357 [Thread-303078] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[]'
> 00:23:43.357 [Thread-303078] TRACE o.c.f.fuse.locks.DataRLockImpl - Acquired read data lock for '[]'
> 00:23:43.357 [Thread-303078] TRACE o.c.frontend.fuse.ReadOnlyAdapter - getattr / (lastModifiedTime: 2022-02-11T23:21:50.6717255Z, lastAccessTime: 2022-02-11T23:23:42.6800988Z, creationTime: 2022-02-05T22:18:13.7328071Z, isRegularFile: false, isDirectory: true, isSymbolicLink: false, isOther: false, size: 20480, fileKey: null)
> 00:23:43.357 [Thread-303078] TRACE o.c.f.fuse.locks.DataRLockImpl - Released read data lock for '[]'
> 00:23:43.357 [Thread-303078] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[]'
> 00:23:43.359 [Thread-303079] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[]'
> 00:23:43.360 [Thread-303079] TRACE o.c.f.fuse.locks.DataRLockImpl - Acquired read data lock for '[]'
> 00:23:43.360 [Thread-303079] TRACE o.c.frontend.fuse.ReadOnlyAdapter - getattr / (lastModifiedTime: 2022-02-11T23:21:50.6717255Z, lastAccessTime: 2022-02-11T23:23:42.6800988Z, creationTime: 2022-02-05T22:18:13.7328071Z, isRegularFile: false, isDirectory: true, isSymbolicLink: false, isOther: false, size: 20480, fileKey: null)
> 00:23:43.360 [Thread-303079] TRACE o.c.f.fuse.locks.DataRLockImpl - Released read data lock for '[]'
> 00:23:43.360 [Thread-303079] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[]'
> 00:23:43.360 [Thread-303080] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[]'
> 00:23:43.360 [Thread-303080] TRACE o.c.f.fuse.locks.DataRLockImpl - Acquired read data lock for '[]'
> 00:23:43.360 [Thread-303080] TRACE o.c.frontend.fuse.ReadOnlyAdapter - getattr / (lastModifiedTime: 2022-02-11T23:21:50.6717255Z, lastAccessTime: 2022-02-11T23:23:42.6800988Z, creationTime: 2022-02-05T22:18:13.7328071Z, isRegularFile: false, isDirectory: true, isSymbolicLink: false, isOther: false, size: 20480, fileKey: null)
> 00:23:43.360 [Thread-303080] TRACE o.c.f.fuse.locks.DataRLockImpl - Released read data lock for '[]'
> 00:23:43.360 [Thread-303080] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[]'
> 00:23:43.360 [Thread-303081] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[]'
> 00:23:43.360 [Thread-303081] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[, Textdokument (neu).txt]'
> 00:23:43.360 [Thread-303081] TRACE o.c.f.fuse.locks.DataRLockImpl - Acquired read data lock for '[, Textdokument (neu).txt]'
> 00:23:43.360 [Thread-303081] TRACE o.c.frontend.fuse.ReadOnlyAdapter - getattr /Textdokument (neu).txt (lastModifiedTime: 2022-02-11T23:21:53.8942396Z, lastAccessTime: 2022-02-11T23:23:42.6930639Z, creationTime: 2022-02-11T23:21:50.6717255Z, isRegularFile: true, isDirectory: false, isSymbolicLink: false, isOther: false, size: 4, fileKey: null)
> 00:23:43.360 [Thread-303081] TRACE o.c.f.fuse.locks.DataRLockImpl - Released read data lock for '[, Textdokument (neu).txt]'
> 00:23:43.360 [Thread-303081] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[, Textdokument (neu).txt]'
> 00:23:43.360 [Thread-303081] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[]'
> 00:23:43.360 [Thread-303082] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[]'
> 00:23:43.361 [Thread-303082] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[, Textdokument (neu).txt]'
> 00:23:43.361 [Thread-303082] TRACE o.c.f.fuse.locks.DataRLockImpl - Acquired read data lock for '[, Textdokument (neu).txt]'
> 00:23:43.361 [Thread-303082] TRACE o.c.frontend.fuse.ReadOnlyAdapter - getattr /Textdokument (neu).txt (lastModifiedTime: 2022-02-11T23:21:53.8942396Z, lastAccessTime: 2022-02-11T23:23:42.6930639Z, creationTime: 2022-02-11T23:21:50.6717255Z, isRegularFile: true, isDirectory: false, isSymbolicLink: false, isOther: false, size: 4, fileKey: null)
> 00:23:43.361 [Thread-303082] TRACE o.c.f.fuse.locks.DataRLockImpl - Released read data lock for '[, Textdokument (neu).txt]'
> 00:23:43.361 [Thread-303082] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[, Textdokument (neu).txt]'
> 00:23:43.361 [Thread-303082] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[]'
> 00:23:43.361 [Thread-303083] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[]'
> 00:23:43.361 [Thread-303083] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[, Textdokument (neu).txt]'
> 00:23:43.361 [Thread-303083] TRACE o.c.f.fuse.locks.DataRLockImpl - Acquired read data lock for '[, Textdokument (neu).txt]'
> 00:23:43.361 [Thread-303083] TRACE o.c.frontend.fuse.ReadOnlyAdapter - getattr /Textdokument (neu).txt (lastModifiedTime: 2022-02-11T23:21:53.8942396Z, lastAccessTime: 2022-02-11T23:23:42.6930639Z, creationTime: 2022-02-11T23:21:50.6717255Z, isRegularFile: true, isDirectory: false, isSymbolicLink: false, isOther: false, size: 4, fileKey: null)
> 00:23:43.361 [Thread-303083] TRACE o.c.f.fuse.locks.DataRLockImpl - Released read data lock for '[, Textdokument (neu).txt]'
> 00:23:43.361 [Thread-303083] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[, Textdokument (neu).txt]'
> 00:23:43.361 [Thread-303083] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[]'
> 00:23:43.361 [Thread-303084] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[]'
> 00:23:43.361 [Thread-303084] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[, Textdokument (neu).txt]'
> 00:23:43.361 [Thread-303084] TRACE o.c.f.fuse.locks.DataRLockImpl - Acquired read data lock for '[, Textdokument (neu).txt]'
> 00:23:43.361 [Thread-303084] TRACE o.c.frontend.fuse.ReadOnlyAdapter - open /Textdokument (neu).txt (0)
> 00:23:43.361 [Thread-303084] TRACE o.c.cryptofs.fh.FileHeaderHolder - Reading file header from C:\Users\rich\sciebo\VAULT\d\LF\LSW6MJ3ECSHHR2M7SDB26MUPB5HU5W\9JuwmjssEv5I1y-xskd1RFPyaFDQuoaWenRAI1H8VjRbpTqEY4g=.c9r
> 00:23:43.361 [Thread-303084] TRACE o.c.cryptofs.fh.OpenCryptoFile - First channel for this openFile. Initializing file size...
> 00:23:43.362 [Thread-303084] TRACE o.c.frontend.fuse.OpenFileFactory - Opening 1432 OpenFile{path=/Textdokument (neu).txt, channel=org.cryptomator.cryptofs.ch.CleartextFileChannel@101b711d}
> 00:23:43.362 [Thread-303084] TRACE o.c.f.fuse.locks.DataRLockImpl - Released read data lock for '[, Textdokument (neu).txt]'
> 00:23:43.362 [Thread-303084] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[, Textdokument (neu).txt]'
> 00:23:43.362 [Thread-303084] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[]'
> 00:23:43.362 [Thread-303085] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[]'
> 00:23:43.362 [Thread-303085] TRACE o.c.f.fuse.locks.PathWLockImpl - Acquired write path lock for '[, Textdokument (neu).txt]'
> 00:23:43.362 [Thread-303085] TRACE o.c.f.fuse.locks.DataWLockImpl - Acquired write data lock for '[, Textdokument (neu).txt]'
> 00:23:43.362 [Thread-303085] TRACE o.c.frontend.fuse.ReadWriteAdapter - unlink /Textdokument (neu).txt
> 00:23:43.362 [Thread-303085] TRACE o.c.f.fuse.locks.DataWLockImpl - Released write data lock for '[, Textdokument (neu).txt]'
> 00:23:43.362 [Thread-303085] TRACE o.c.f.fuse.locks.PathWLockImpl - Released write path lock for '[, Textdokument (neu).txt]'
> 00:23:43.362 [Thread-303085] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[]'
> 00:23:43.363 [Thread-303086] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[]'
> 00:23:43.363 [Thread-303086] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[, Textdokument (neu).txt]'
> 00:23:43.363 [Thread-303086] TRACE o.c.f.fuse.locks.DataRLockImpl - Acquired read data lock for '[, Textdokument (neu).txt]'
> 00:23:43.363 [Thread-303086] TRACE o.c.frontend.fuse.ReadOnlyAdapter - release /Textdokument (neu).txt (1432)
> 00:23:43.363 [Thread-303086] TRACE o.c.frontend.fuse.OpenFileFactory - Releasing 1432 OpenFile{path=/Textdokument (neu).txt, channel=org.cryptomator.cryptofs.ch.CleartextFileChannel@101b711d}
> 00:23:43.363 [Thread-303086] TRACE o.c.f.fuse.locks.DataRLockImpl - Released read data lock for '[, Textdokument (neu).txt]'
> 00:23:43.363 [Thread-303086] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[, Textdokument (neu).txt]'
> 00:23:43.363 [Thread-303087] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[]'
> 00:23:43.363 [Thread-303086] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[]'
> 00:23:43.363 [Thread-303087] TRACE o.c.f.fuse.locks.DataRLockImpl - Acquired read data lock for '[]'
> 00:23:43.363 [Thread-303087] TRACE o.c.frontend.fuse.ReadOnlyAdapter - getattr / (lastModifiedTime: 2022-02-11T23:23:43.3622863Z, lastAccessTime: 2022-02-11T23:23:43.3622863Z, creationTime: 2022-02-05T22:18:13.7328071Z, isRegularFile: false, isDirectory: true, isSymbolicLink: false, isOther: false, size: 20480, fileKey: null)
> 00:23:43.363 [Thread-303087] TRACE o.c.f.fuse.locks.DataRLockImpl - Released read data lock for '[]'
> 00:23:43.363 [Thread-303087] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[]'
> 00:23:43.363 [Thread-303086] ERROR o.c.frontend.fuse.ReadOnlyAdapter - release /Textdokument (neu).txt failed.
> java.nio.file.NoSuchFileException: C:\Users\rich\sciebo\VAULT\d\LF\LSW6MJ3ECSHHR2M7SDB26MUPB5HU5W\9JuwmjssEv5I1y-xskd1RFPyaFDQuoaWenRAI1H8VjRbpTqEY4g=.c9r
> at java.base/sun.nio.fs.WindowsException.translateToIOException(Unknown Source)
> at java.base/sun.nio.fs.WindowsException.rethrowAsIOException(Unknown Source)
> at java.base/sun.nio.fs.WindowsFileAttributeViews$Basic.setFileTimes(Unknown Source)
> at java.base/sun.nio.fs.WindowsFileAttributeViews$Basic.setTimes(Unknown Source)
> at org.cryptomator.cryptofs@2.3.1/org.cryptomator.cryptofs.ch.CleartextFileChannel.persistLastModified(CleartextFileChannel.java:238)
> at org.cryptomator.cryptofs@2.3.1/org.cryptomator.cryptofs.ch.CleartextFileChannel.implCloseChannel(CleartextFileChannel.java:306)
> at java.base/java.nio.channels.spi.AbstractInterruptibleChannel.close(Unknown Source)
> at org.cryptomator.frontend.fuse@1.3.3/org.cryptomator.frontend.fuse.OpenFile.close(OpenFile.java:103)
> at org.cryptomator.frontend.fuse@1.3.3/org.cryptomator.frontend.fuse.OpenFileFactory.close(OpenFileFactory.java:78)
> at org.cryptomator.frontend.fuse@1.3.3/org.cryptomator.frontend.fuse.ReadOnlyFileHandler.release(ReadOnlyFileHandler.java:81)
> at org.cryptomator.frontend.fuse@1.3.3/org.cryptomator.frontend.fuse.ReadOnlyAdapter.release(ReadOnlyAdapter.java:247)
> at ru.serce.jnrfuse.AbstractFuseFS.lambda$init$7(AbstractFuseFS.java:150)
> at jnr.ffi.provider.jffi.NativeClosureProxy$$impl$$14.invoke(Unknown Source)
> 00:23:43.363 [Thread-303088] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[]'
> 00:23:43.363 [Thread-303088] TRACE o.c.f.fuse.locks.DataRLockImpl - Acquired read data lock for '[]'
> 00:23:43.363 [Thread-303088] TRACE o.c.frontend.fuse.ReadOnlyAdapter - getattr / (lastModifiedTime: 2022-02-11T23:23:43.3622863Z, lastAccessTime: 2022-02-11T23:23:43.3622863Z, creationTime: 2022-02-05T22:18:13.7328071Z, isRegularFile: false, isDirectory: true, isSymbolicLink: false, isOther: false, size: 20480, fileKey: null)
> 00:23:43.363 [Thread-303088] TRACE o.c.f.fuse.locks.DataRLockImpl - Released read data lock for '[]'
> 00:23:43.363 [Thread-303088] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[]'
> 00:23:43.365 [Thread-303089] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[]'
> 00:23:43.365 [Thread-303089] TRACE o.c.f.fuse.locks.DataRLockImpl - Acquired read data lock for '[]'
> 00:23:43.365 [Thread-303089] TRACE o.c.frontend.fuse.ReadOnlyAdapter - getattr / (lastModifiedTime: 2022-02-11T23:23:43.3622863Z, lastAccessTime: 2022-02-11T23:23:43.3622863Z, creationTime: 2022-02-05T22:18:13.7328071Z, isRegularFile: false, isDirectory: true, isSymbolicLink: false, isOther: false, size: 20480, fileKey: null)
> 00:23:43.365 [Thread-303089] TRACE o.c.f.fuse.locks.DataRLockImpl - Released read data lock for '[]'
> 00:23:43.365 [Thread-303089] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[]'
> 00:23:43.366 [Thread-303090] TRACE o.c.f.fuse.locks.PathRLockImpl - Acquired read path lock for '[]'
> 00:23:43.366 [Thread-303090] TRACE o.c.f.fuse.locks.DataRLockImpl - Acquired read data lock for '[]'
