Im having issues when uploading files to my vault via webdav. File upload cancels and gives an error.
The following is my device typ dont know why its missing from the log:
20240417195150.285 | App | Cryptomator v1.10.0 (2824) Google Play Edition started on android 14 / API34 using a SM-S901B | |
I | 20240417195150.325 | Database | Configure v12 |
I | 20240417195150.325 | Database | Open v12 |
I | 20240417195150.354 | ActivityLifecycle | onResume org.cryptomator.presentation.ui.activity.VaultListActivity@eaf64d9 |
I | 20240417195150.427 | App | Cryptors service connected |
I | 20240417195150.428 | App | Cryptors service connected |
I | 20240417195150.429 | App | Auto upload service connected |
I | 20240417195152.291 | ActivityLifecycle | onResume org.cryptomator.presentation.ui.activity.SettingsActivity@bab3ddf |
org.cryptomator.domain.usecases.cloud.UploadState@8bf42da: complete
V 20240417195529.733 Progress ENCRYPTION 100%
V 20240417195529.734 Progress ENCRYPTION 100%
V 20240417195529.735 Progress ENCRYPTION 100%
D 20240417195529.735 OkHttp --> PROPFIND https://webdav.example.com/folder1/CR3/d/7X/QQLXM7M2LRF4E7SKEKEUGIK5DF5ONX/w0xGtrecX7-TeJe5SKkzvFlx-RSzIVw9VSvHg3SlgKvPSYJN7_8NgFuj.c9r http/1.1 (205-byte body)
D 20240417195529.735 OkHttp Content-Length: 205
D 20240417195529.735 OkHttp DEPTH: 0
D 20240417195529.735 OkHttp --> END PROPFIND
D 20240417195529.861 OkHttp <-- 404 https://webdav.example.com/folder1/CR3/d/7X/QQLXM7M2LRF4E7SKEKEUGIK5DF5ONX/w0xGtrecX7-TeJe5SKkzvFlx-RSzIVw9VSvHg3SlgKvPSYJN7_8NgFuj.c9r (125ms)
D 20240417195529.862 OkHttp server: nginx
D 20240417195529.862 OkHttp date: Wed, 17 Apr 2024 17:55:30 GMT
D 20240417195529.862 OkHttp Cache-Control: max-age=0
D 20240417195529.862 OkHttp <-- END HTTP
D 20240417195529.869 OkHttp --> PROPFIND https://webdav.example.com/folder1/CR3/d/7X/QQLXM7M2LRF4E7SKEKEUGIK5DF5ONX/w0xGtrecX7-TeJe5SKkzvFlx-RSzIVw9VSvHg3SlgKvPSYJN7_8NgFuj.c9r http/1.1 (205-byte body)
D 20240417195529.869 OkHttp Content-Length: 205
D 20240417195529.869 OkHttp DEPTH: 0
D 20240417195529.869 OkHttp --> END PROPFIND
D 20240417195529.885 OkHttp <-- 404 https://webdav.example.com/folder1/CR3/d/7X/QQLXM7M2LRF4E7SKEKEUGIK5DF5ONX/w0xGtrecX7-TeJe5SKkzvFlx-RSzIVw9VSvHg3SlgKvPSYJN7_8NgFuj.c9r (15ms)
D 20240417195529.885 OkHttp server: nginx
D 20240417195529.885 OkHttp date: Wed, 17 Apr 2024 17:55:30 GMT
D 20240417195529.885 OkHttp Cache-Control: max-age=0
D 20240417195529.885 OkHttp <-- END HTTP
V 20240417195529.895 Progress org.cryptomator.domain.usecases.cloud.UploadState@2385f3d: 0%
D 20240417195529.899 OkHttp --> PUT https://webdav.example.com/folder1/CR3/d/7X/QQLXM7M2LRF4E7SKEKEUGIK5DF5ONX/w0xGtrecX7-TeJe5SKkzvFlx-RSzIVw9VSvHg3SlgKvPSYJN7_8NgFuj.c9r http/1.1 (0-byte body)
V 20240417195529.899 Progress UPLOAD 0%
D 20240417195529.900 OkHttp Content-Type: application/octet-stream
D 20240417195529.900 OkHttp Content-Length: 0
D 20240417195529.900 OkHttp --> END PUT
V 20240417195529.901 Progress org.cryptomator.domain.usecases.cloud.UploadState@4d0b239: 0%
D 20240417195529.904 OkHttp <-- HTTP FAILED: java.net.ProtocolException: expected 0 bytes but received 8192
V 20240417195529.915 Progress UPLOAD 0%
D 20240417195530.341 UploadFilesUseCase failed 6d3108fc
D 20240417195530.483 ExceptionHandler Unexpected error
org.cryptomator.domain.exception.FatalBackendException: java.net.ProtocolException: expected 0 bytes but received 8192
at org.cryptomator.data.cloud.webdav.network.WebDavClient.writeFile(WebDavClient.kt:170)
at org.cryptomator.data.cloud.webdav.network.ConnectionHandlerHandlerImpl.writeFile(ConnectionHandlerHandlerImpl.kt:31)
at org.cryptomator.data.cloud.webdav.WebDavImpl.write(WebDavImpl.kt:136)
at org.cryptomator.data.cloud.webdav.WebDavCloudContentRepository$Intercepted.write(WebDavCloudContentRepository.kt:165)
at org.cryptomator.data.cloud.webdav.WebDavCloudContentRepository$Intercepted.write(WebDavCloudContentRepository.kt:95)
at org.cryptomator.data.cloud.InterceptingCloudContentRepository.write(InterceptingCloudContentRepository.kt:155)
at org.cryptomator.data.repository.DispatchingCloudContentRepository.write(DispatchingCloudContentRepository.kt:149)
at org.cryptomator.data.cloud.crypto.CryptoImplDecorator.writeFromTmpFile(CryptoImplDecorator.kt:262)
at org.cryptomator.data.cloud.crypto.CryptoImplDecorator.writeShortNameFile(CryptoImplDecorator.kt:453)
at org.cryptomator.data.cloud.crypto.CryptoImplVaultFormat7.write(CryptoImplVaultFormat7.kt:460)
at org.cryptomator.data.cloud.crypto.CryptoCloudContentRepository.write(CryptoCloudContentRepository.kt:90)
at org.cryptomator.data.cloud.crypto.CryptoCloudContentRepository.write(CryptoCloudContentRepository.kt:21)
at org.cryptomator.domain.usecases.cloud.UploadFiles.writeCloudFile(UploadFiles.java:117)
at org.cryptomator.domain.usecases.cloud.UploadFiles.upload(UploadFiles.java:94)
at org.cryptomator.domain.usecases.cloud.UploadFiles.upload(UploadFiles.java:82)
at org.cryptomator.domain.usecases.cloud.UploadFiles.upload(UploadFiles.java:74)
at org.cryptomator.domain.usecases.cloud.UploadFiles.execute(UploadFiles.java:61)
at org.cryptomator.domain.usecases.cloud.UploadFilesUseCase$Launcher$2.subscribe(UploadFilesUseCase.java:119)
at io.reactivex.internal.operators.flowable.FlowableFromPublisher.subscribeActual(FlowableFromPublisher.java:29)
at io.reactivex.Flowable.subscribe(Flowable.java:14935)
at io.reactivex.Flowable.subscribe(Flowable.java:14882)
at io.reactivex.internal.operators.flowable.FlowableSubscribeOn$SubscribeOnSubscriber.run(FlowableSubscribeOn.java:82)
at io.reactivex.internal.schedulers.ExecutorScheduler$ExecutorWorker$BooleanRunnable.run(ExecutorScheduler.java:288)
at io.reactivex.internal.schedulers.ExecutorScheduler$ExecutorWorker.run(ExecutorScheduler.java:253)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:644)
at java.lang.Thread.run(Thread.java:1012)
Caused by: java.net.ProtocolException: expected 0 bytes but received 8192
at okhttp3.internal.connection.Exchange$RequestBodySink.write(Exchange.kt:214)
at okio.RealBufferedSink.emitCompleteSegments(RealBufferedSink.kt:255)
at okio.RealBufferedSink.writeAll(RealBufferedSink.kt:194)
at org.cryptomator.data.cloud.webdav.network.InputStreamSourceBasedRequestBody.writeTo(InputStreamSourceBasedRequestBody.kt:26)
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.kt:59)
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:109)
at org.cryptomator.data.cloud.webdav.network.WebDavCompatibleHttpClient$Companion.provideCacheInterceptor$lambda$1(WebDavCompatibleHttpClient.kt:97)
at org.cryptomator.data.cloud.webdav.network.WebDavCompatibleHttpClient$Companion.$r8$lambda$FEXxZ7SrPDCRzX39O94E81VyuVA(Unknown Source:0)
at org.cryptomator.data.cloud.webdav.network.WebDavCompatibleHttpClient$Companion$$ExternalSyntheticLambda1.intercept(Unknown Source:0)
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.kt:34)
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.kt:95)
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.kt:83)
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.kt:76)
at org.cryptomator.data.cloud.webdav.network.WebDavCompatibleHttpClient$Companion.provideOfflineCacheInterceptor$lambda$0(WebDavCompatibleHttpClient.kt:91)
at org.cryptomator.data.cloud.webdav.network.WebDavCompatibleHttpClient$Companion.$r8$lambda$mK1oDRmeIibu1Q57fFrYEwIb5dg(Unknown Source:0)
at org.cryptomator.data.cloud.webdav.network.WebDavCompatibleHttpClient$Companion$$ExternalSyntheticLambda0.intercept(Unknown Source:0)
at org.cryptomator.data.cloud.webdav.network.WebDavCompatibleHttpClient$UserAgentInterceptor.intercept(WebDavCompatibleHttpClient.kt:153)
at com.burgstaller.okhttp.AuthenticationCacheInterceptor.intercept(AuthenticationCacheInterceptor.java:49)
at org.cryptomator.data.cloud.okhttplogging.HttpLoggingInterceptor.getResponseLoggingExceptions(HttpLoggingInterceptor.kt:51)
at org.cryptomator.data.cloud.okhttplogging.HttpLoggingInterceptor.getAndLogResponse(HttpLoggingInterceptor.kt:42)
at org.cryptomator.data.cloud.okhttplogging.HttpLoggingInterceptor.proceedWithLogging(HttpLoggingInterceptor.kt:28)
at org.cryptomator.data.cloud.okhttplogging.HttpLoggingInterceptor.intercept(HttpLoggingInterceptor.kt:18)
at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(RealCall.kt:201)
at okhttp3.internal.connection.RealCall.execute(RealCall.kt:154)
at org.cryptomator.data.cloud.webdav.network.WebDavRedirectHandler.executeFollowingRedirects(WebDavRedirectHandler.kt:21)
at org.cryptomator.data.cloud.webdav.network.WebDavCompatibleHttpClient.execute(WebDavCompatibleHttpClient.kt:44)
at org.cryptomator.data.cloud.webdav.network.WebDavCompatibleHttpClient.execute(WebDavCompatibleHttpClient.kt:39)
at org.cryptomator.data.cloud.webdav.network.WebDavClient.writeFile(WebDavClient.kt:158)
... 27 more
ErrorCode: 611A:JB59
E 20240417195530.490 ExceptionHandler org.cryptomator.domain.exception.FatalBackendException: java.net.ProtocolException: expected 0 bytes but received 8192
... 27 more
W 20240417195530.586 Message Ein Fehler ist aufgetreten
D 20240417195530.591 AssertUnlockedUseCase started 6d310902
D 20240417195530.591 AssertUnlockedUseCase finished 6d310902
V 20240417195534.932 FragmentLifecycle onPause BrowseFilesFragment{1e5c6fb} (10d1e6ff-0741-4ab5-8a3e-bea10e623e27 id=0x7f0a0123)
V 20240417195534.932 FragmentLifecycle onStop BrowseFilesFragment{1e5c6fb} (10d1e6ff-0741-4ab5-8a3e-bea10e623e27 id=0x7f0a0123)
V 20240417195534.933 FragmentLifecycle onCreateView BrowseFilesFragment{b020855} (270d35a7-7399-4828-898c-77257e914dfb id=0x7f0a0123)
V 20240417195534.947 FragmentLifecycle onViewCreated BrowseFilesFragment{b020855} (270d35a7-7399-4828-898c-77257e914dfb id=0x7f0a0123)
V 20240417195534.947 FragmentLifecycle onActivityCreated BrowseFilesFragment{b020855} (270d35a7-7399-4828-898c-77257e914dfb id=0x7f0a0123)
V 20240417195534.949 FragmentLifecycle onStart BrowseFilesFragment{b020855} (270d35a7-7399-4828-898c-77257e914dfb id=0x7f0a0123)
D 20240417195534.953 GetCloudListUseCase started 6d310900
D 20240417195534.955 OkHttp --> PROPFIND https://webdav.example.com/folder1/CR3/d/44/NJVWGRRZNBS5H6PPUFNFYTTOT2GNBA http/1.1 (205-byte body)
D 20240417195534.955 OkHttp Content-Length: 205
D 20240417195534.955 OkHttp DEPTH: 1
D 20240417195534.955 OkHttp --> END PROPFIND
D 20240417195534.977 OkHttp <-- 207 https://webdav.example.com/folder1/CR3/d/44/NJVWGRRZNBS5H6PPUFNFYTTOT2GNBA (21ms)
D 20240417195534.977 OkHttp server: nginx
D 20240417195534.978 OkHttp date: Wed, 17 Apr 2024 17:55:35 GMT
D 20240417195534.978 OkHttp Cache-Control: max-age=0
D 20240417195534.978 OkHttp <-- END HTTP
W 20240417195534.995 CryptoFs Failed to parse cipher text name of: /folder1/CR3/d/44/NJVWGRRZNBS5H6PPUFNFYTTOT2GNBA/dirid.c9r
D 20240417195535.000 GetCloudListUseCase finished 6d310900
V 20240417195535.363 FragmentLifecycle onDestroyView BrowseFilesFragment{1e5c6fb} (10d1e6ff-0741-4ab5-8a3e-bea10e623e27 id=0x7f0a0123)
V 20240417195535.364 FragmentLifecycle onDestroy BrowseFilesFragment{1e5c6fb} (10d1e6ff-0741-4ab5-8a3e-bea10e623e27 id=0x7f0a0123)
V 20240417195535.364 FragmentLifecycle onResume BrowseFilesFragment{b020855} (270d35a7-7399-4828-898c-77257e914dfb id=0x7f0a0123)
D 20240417195537.344 AssertUnlockedUseCase started 6d310903
D 20240417195537.344 AssertUnlockedUseCase finished 6d310903
D 20240417195537.571 ActivityLifecycle finish org.cryptomator.presentation.ui.activity.BrowseFilesActivity@c83a457
V 20240417195537.583 FragmentLifecycle onPause BrowseFilesFragment{b020855} (270d35a7-7399-4828-898c-77257e914dfb id=0x7f0a0123)
D 20240417195537.583 ActivityLifecycle onPause org.cryptomator.presentation.ui.activity.BrowseFilesActivity@c83a457
D 20240417195537.583 PresenterLifecycle pause org.cryptomator.presentation.presenter.BrowseFilesPresenter@cc2dbd5
D 20240417195537.596 ActivityLifecycle onRestart org.cryptomator.presentation.ui.activity.VaultListActivity@eaf64d9
V 20240417195537.596 FragmentLifecycle onStart VaultListFragment{d2a6bef} (8ca1a6d6-61a6-44ab-9125-6512ad9c7896 id=0x7f0a0123)
D 20240417195537.596 ActivityLifecycle onStart org.cryptomator.presentation.ui.activity.VaultListActivity@eaf64d9
I 20240417195537.599 ActivityLifecycle onResume org.cryptomator.presentation.ui.activity.VaultListActivity@eaf64d9
V 20240417195537.600 FragmentLifecycle onResume VaultListFragment{d2a6bef} (8ca1a6d6-61a6-44ab-9125-6512ad9c7896 id=0x7f0a0123)
D 20240417195537.600 ActivityLifecycle onResumeFragments org.cryptomator.presentation.ui.activity.VaultListActivity@eaf64d9
D 20240417195537.600 PresenterLifecycle resume org.cryptomator.presentation.presenter.VaultListPresenter@97759a1
D 20240417195537.600 GetVaultListUseCase started 6d2fb43c
D 20240417195537.603 GetVaultListUseCase finished 6d2fb43c
D 20240417195537.677 GetVaultListUseCase started 6d2fb43d
D 20240417195537.678 GetVaultListUseCase finished 6d2fb43d
V 20240417195538.092 FragmentLifecycle onStop BrowseFilesFragment{b020855} (270d35a7-7399-4828-898c-77257e914dfb id=0x7f0a0123)
D 20240417195538.092 ActivityLifecycle onStop org.cryptomator.presentation.ui.activity.BrowseFilesActivity@c83a457
V 20240417195538.094 FragmentLifecycle onDestroyView BrowseFilesFragment{b020855} (270d35a7-7399-4828-898c-77257e914dfb id=0x7f0a0123)
V 20240417195538.094 FragmentLifecycle onDestroy BrowseFilesFragment{b020855} (270d35a7-7399-4828-898c-77257e914dfb id=0x7f0a0123)
D 20240417195538.094 ActivityLifecycle onDestroy org.cryptomator.presentation.ui.activity.BrowseFilesActivity@c83a457
D 20240417195538.094 PresenterLifecycle destroy org.cryptomator.presentation.presenter.BrowseFilesPresenter@cc2dbd5
V 20240417195539.218 FragmentLifecycle onPause VaultListFragment{d2a6bef} (8ca1a6d6-61a6-44ab-9125-6512ad9c7896 id=0x7f0a0123)
D 20240417195539.219 ActivityLifecycle onPause org.cryptomator.presentation.ui.activity.VaultListActivity@eaf64d9
D 20240417195539.219 PresenterLifecycle pause org.cryptomator.presentation.presenter.VaultListPresenter@97759a1
D 20240417195539.236 ActivityLifecycle onCreate org.cryptomator.presentation.ui.activity.SettingsActivity@e1ce29
D 20240417195539.276 ActivityLifecycle onStart org.cryptomator.presentation.ui.activity.SettingsActivity@e1ce29
I 20240417195539.278 ActivityLifecycle onResume org.cryptomator.presentation.ui.activity.SettingsActivity@e1ce29
D 20240417195539.279 ActivityLifecycle onResumeFragments org.cryptomator.presentation.ui.activity.SettingsActivity@e1ce29
D 20240417195539.279 PresenterLifecycle resume org.cryptomator.presentation.presenter.SettingsPresenter@ab59dd4
V 20240417195539.838 FragmentLifecycle onStop VaultListFragment{d2a6bef} (8ca1a6d6-61a6-44ab-9125-6512ad9c7896 id=0x7f0a0123)
D 20240417195539.839 ActivityLifecycle onStop org.cryptomator.presentation.ui.activity.VaultListActivity@eaf64d9
D 20240417195539.840 ActivityLifecycle onSaveInstanceState org.cryptomator.presentation.ui.activity.VaultListActivity@eaf64d9
V 20240417195543.723 Progress UNKNOWN_MIMETYPE -1%
